_ethrty-Andy_ 2152 Report post Posted April 18, 2014 Hey guys, need to change upper sump pan gasket on the M70. Anyone know if it is possible to remove the upper sump this with the transmission still in place? Decides how the best way to tackle this is. Also have front and rear crank seals, but will replace rear crank one at a later date if transmission does not need to come out, its not leaking from the back at all. 1 Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted April 18, 2014 Yes...unless there are restrictions because it's not in the car it was built to be in 2 Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2152 Report post Posted April 18, 2014 Yes...unless there are restrictions because it's not in the car it was built to be in cheers, yep, going to be a real PITA to take the transmission out, it might not even be possible, probably would have to pull the whole lot out. Looking like a slightly easier job this weekend than first thought then! (should have really done it in the first place but too late for hindsight now!!!) Quote Share this post Link to post Share on other sites
