allan 295 Report post Posted April 18, 2014 Hi, electrical gurrues Have a low fluid windscreen washer bottle light on. The vehicle has been scanned and the sensor replaced but still the light remains on checking the wiring with an ohm meter and have a circuit even tried another washer bottle and moved the float up and down. Connect it all back up and light still on. Have I missed something or is a cluster fault help most welcome thanks. Quote Share this post Link to post Share on other sites
elmarco 56 Report post Posted April 18, 2014 Did you fill it with water? 1 Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2152 Report post Posted April 18, 2014 plugged in behind the cluster? (not familiar enough with E46 sorry) Quote Share this post Link to post Share on other sites
allan 295 Report post Posted April 19, 2014 Yes the bottle is full of water checked both full, empty and moving the float up and down. The testing was done with it unplugged from the cluster and then replugged it back into the cluster making sure that the connecter had engaged correctly and able to move the securing arm and lock it in place. Quote Share this post Link to post Share on other sites
JaseNZ 53 Report post Posted April 19, 2014 (edited) have a read of the last post of this thread. http://www.m3forum.net/m3forum/showthread.php?t=360221 Edited April 19, 2014 by M-Spec Quote Share this post Link to post Share on other sites
allan 295 Report post Posted April 19, 2014 (edited) Thanks , on the ti it does not go their it leaves the sensor connector located at the front of the washer bottle goes to the loom which has head lights, horn, fog light etc runs up the inner guard in the engine bay past the top of the strut tower under the protection panel for the brake booster under that and through the firewall via a large rubber grommet. https://www.google.co.nz/search?newwindow=1&hl=en&site=imghp&tbm=isch&source=hp&biw=1426&bih=766&q=e46+ti+engine+bay&oq=e46+ti+engine+bay&gs_l=img.12...0.0.0.4499.0.0.0.0.0.0.0.0..0.0....0...1ac..41.img..0.0.0.Ss4Lkeulihg#facrc=_&imgdii=ufyFjKaTHU2GrM%3A%3BP1lNxNIvfj7fjM%3BufyFjKaTHU2GrM%3A&imgrc=ufyFjKaTHU2GrM%253A%3BAW1TaaOSlC1kuM%3Bhttp%253A%252F%252Fwww.xs4all.nl%252F~ebiemold%252FBMW%252Fcompact%252Fbmw001.JPG%3Bhttp%253A%252F%252Fwww.bimmerfest.com%252Fforums%252Fshowthread.php%253Ft%253D143126%3B708%3B532 Edited April 19, 2014 by tim 325 Quote Share this post Link to post Share on other sites
