samo455 7 Report post Posted April 29, 2014 (edited) hay everybody I'm at it again I'm putting a new ecu in my m50 I'm after 3 plug from a loom only need to have enough wire to solder to 20mm will do need 1x cam angel sensor plug female loom end also 2x knock sensor loom end thanks guys Edited April 29, 2014 by samo455 Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted April 29, 2014 can do. I'll need to double check which is m50 and 52. you dont have any part numbers or pictures so i can be sure? Quote Share this post Link to post Share on other sites
Arron 227 Report post Posted April 29, 2014 arghhhh only through one out at the weekend......... Quote Share this post Link to post Share on other sites
samo455 7 Report post Posted April 30, 2014 can do. I'll need to double check which is m50 and 52. you dont have any part numbers or pictures so i can be sure? cant find any part numbers but ill keep looking ill try take some pics tonyt its m50tu so gess m52 would be the same Quote Share this post Link to post Share on other sites
