sonic_attack
M60B40 Water Pump
Don't suppose anyone's got one of these sitting around for pickup in Aucks this weekend. New preferably. Just the hose clamp variety.
Long shot I know.
Rod 0275366468
I have a contact that imports water pumps for repco, apco, part world etc. what's the part number your after?
Sent from my iPhone using Tapatalk
Haha no worries. Good luck with that. I know how you feel, I'm stripping an E39 touring
Yeah, Charming job.
Halfway through and need a 19mm O-ring for one of those bast@rd ali tubes running under the plenum chamber. And why someone decided to put one of the bolts behind the crank pulley is an oddity.
Interesting to note though the pump supplied by NZAD is a metal impeller as opposed to the plastic/composite one that's crapped itself. There's probably a reasonable reason for the plastic, I don't like it though.
Cheers again.
Very common for new ones to be metal. Most people refuse to use plastic again as its a big weak point
