d.p.n.s 15 Report post Posted June 1, 2014 hi all just wondering if the factory auto will hold up to a m50b25 turbo. not really wanting to go manual. Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted June 1, 2014 I've spent a lot of time with Porsche 928s. Typically, the standard autobox fitted to them is expected to handle more power and torque than the manuals. That's not always the case. Ultimately, the way you drive will be more important than the gearbox you use. Slamming an auto through the gears will break it. Quote Share this post Link to post Share on other sites
d.p.n.s 15 Report post Posted June 1, 2014 the reason im asking is this is my daily driver a 93 e34 touring and im wanting to make a wee bit of a sleeper out of it. im planning on using a 1uz-fe auto and turboing it......but if the bmw autos are upto it I may consider turboing the m50b25. I know the 1uz auto is up to it Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted June 1, 2014 It's not the first time it has been done, but those conversions I've seen using the Lexus V8 have also used the Lexus gearbox. See here for one example.There was an E28 ex-535i fitted with a Lexus V8 for sale on TradeMe recently, also (I think) turbo'd. IIRC that used the Lexus 'box. Quote Share this post Link to post Share on other sites
d.p.n.s 15 Report post Posted June 1, 2014 It's not the first time it has been done, but those conversions I've seen using the Lexus V8 have also used the Lexus gearbox. See here for one example. There was an E28 ex-535i fitted with a Lexus V8 for sale on TradeMe recently, also (I think) turbo'd. IIRC that used the Lexus 'box. ive got a 1uz in my e30 but I made that manual.....doing the 1uz swap is easy .....but if the factory bmw auto can handle say 10lb max then I might be keen or doing a m50b25 turbo this time around. Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted June 1, 2014 i wouldnt advise it 1 Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted June 13, 2014 If you wanted to make an M50 turbo you'd have to find an autobox that easily works.... you'd need it's original gearbox(easier to manual convert than wire in an extra e30's worth of sh*t) the ZF4HP22 can handle boost, but again why, it'd be dumb. 1 Quote Share this post Link to post Share on other sites
