rollas22 0 Report post Posted November 1, 2005 hi im putting the head back on in my bmw 320i and i need the camchain diagram to get the timing right. Please can you bimmersport members help??? 1986 320i (4cylinder) bmw, manual, 4door. It is camchain driven not cambelt. Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted November 1, 2005 86 320? Thats 4 cylinder? Sure you don't have a 318? Quote Share this post Link to post Share on other sites
petone 0 Report post Posted November 1, 2005 Maybe he's got a 2L block in there? Otherwise andrews right. Will definatly be the M10 though. Whats you email, I can email you part of the haynes manual if you want, might help you. Quote Share this post Link to post Share on other sites
topless 14 Report post Posted November 1, 2005 Photo shows camshaft aligning marks. The lower timing cover needs to be temp refitted along with the crank pulley and the notch on the pulley is to be aligned with the pointer on the timing cover. Align camshaft as per photo. Quote Share this post Link to post Share on other sites
rollas22 0 Report post Posted November 1, 2005 Thanks. Car is registered as a 320i.... i just assumed it had a 2.0l in it, which im sure it does. Is there any special markings on the crank pully that i have to line up as well??? need the full diagrams. Quote Share this post Link to post Share on other sites
rollas22 0 Report post Posted November 3, 2005 I have no notch on my pulley.... and no marks on my cover. im assuming its behind all of that??? Quote Share this post Link to post Share on other sites
