Dn540
E39 Integral Link/Ball Joint
Hi Folks,
Just wondering if anyone has done their integral links/ball joints and where you bought/rented the ball joint press tool from?
Took the 540 in for a wof today and failed on those bushings.
I was looking at this DIY before but wanted to know if anyone in NZ had any experience with theirs?
http://www.beisansystems.com/procedures/swing_arm_ball_joints_procedure.htm
Just use a rattle gun, some high tensile threaded rod with nuts and big washers and a socket or a bit of pipe to press into and to press out with.
That's what I used to do my ones and most of my rear bushes when I had the subframe out
Edited by euroriffic
Great, thanks. Dad has a load of tools (mechanic) so will see what I can find in the abyss. We've definitely used that pipe/rod method before, especially on the 190.
Did you source your bushes in town or import?
I got all my stuff through Paul at Milland. He's local and just works from his house. He has a lot of bits on trademe and a good place to see if he has in stock which he probably will
Ah magic, thanks. I've dealt with him before and didn't even remember to ask him! Bought replacement cabin filters.
Will flick him a message now.
Yea Paul's the man! He doesn't usually check work emails during the weekend so might not hear from him till Monday
