allan 295 Report post Posted July 1, 2014 Looking for a medium case 3.15 to 1 ratio diff for a 2002 e46 have a few inquires out but coming up short so far so thought I would ask on here. Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted July 1, 2014 Out of curiosity, what ratio is in there currently? I used a 3.15 (added LS center later) on my manual conversion. As the M50B25 isn't an overly torquey motor I wish I'd gone with the 3.46 instead. Doesn't make that much difference to the revs at 60mph and just shortens up the acceleration nicely. Food for thought anyway Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted July 1, 2014 have a e36 3.15 , use the gears out of that and fit into a e46 diff case Quote Share this post Link to post Share on other sites
allan 295 Report post Posted July 1, 2014 It still has the small case 3.38 to 1 in it and 5th comes up quick around 2,900rpm for 100k good in the go department but not for fuel economy. Hence the look at changing and most of the reading I 've done points to the 3.15 to 1 being a good balance. Will keep it in mind the crown wheel and pinion option but was hoping for a straight swap over. Still have a few inquires to come back so time will tell. Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted July 1, 2014 Ok you will need the matching larger axles to match the diff Quote Share this post Link to post Share on other sites
allan 295 Report post Posted July 1, 2014 (edited) Have complete rear arms with shafts already from donor car. The only difference I can find so far is the bolt spacings on the shaft flange that bolts to the out put flange on the diff. Edited July 1, 2014 by tim 325 Quote Share this post Link to post Share on other sites
