Jamez 2147483647 Report post Posted July 15, 2014 Anyone know what the standard clutch thickness on a S50B32 is with a dual mass flywheel? ideally the minimum thickness as well. Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted July 15, 2014 Try ringing Auto Clutch James. TIS only gives a minimum thickness of 1mm from lining surface to top of rivet head Quote Share this post Link to post Share on other sites
Jamez 2147483647 Report post Posted July 16, 2014 Standard clutch thickness is 9.5mm, wear tolerance is 1-1.5mm. I had a 8mm clutch disk and it was still usable but only just usable, I guess that confirms the above information. Quote Share this post Link to post Share on other sites
