Herbmiester 947 Report post Posted July 16, 2014 My E36 has no heat or A/C. The A/C button lights up when I press and the fan works fine in manual mode. The unit is the climate control with twin temperature dials out of a 94 325i Coupe. I have done a bit of research and I think it could be the heater valve is not working combined with the A/C needing to be re-gassed but I would appreciate anyone elses thoughts here before I start pulling things apart. Herb Quote Share this post Link to post Share on other sites
KwS 2448 Report post Posted July 16, 2014 (edited) Likely to different issues like you say. The heater valve issue is really common, and easy to fix (with a replacement valve). i did mine on my M3 when i got it. http://bimmersport.co.nz/topic/48843-e36-m3-resto-mod/page-2#entry527611 Should be similar. Sourced the replacement valve from HellBM. Edited July 16, 2014 by KwS Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted July 16, 2014 Good stuff thanks for that. Quote Share this post Link to post Share on other sites
