JJohnsen88 9 Report post Posted August 18, 2014 So it's a 328i with auto dual climate control, I get very mildly warm air coming from all vents, heat doesn't vary between switching vents like my other E36, and it's not thermostat as temp gauge sits at it's normal position, the AC works blowing chilled air but still no hot only luke warm. I have done a bit of searching and leaning towards heater control valve. I'm just fishing for any things I could look at or maybe a way to bypass the control valve to see if that helps. I don't have a volt meter which would make life alot easier I know but any ideas would be helpful. I'm sick of freezing my ass off in the car! Quote Share this post Link to post Share on other sites
KwS 2448 Report post Posted August 18, 2014 (edited) Take the valve out, pretty easy, 3 hoses and an electrical connector. Should be fairly obvious looking into the connections if its blocked. Theres a few members handy with a spanner down there in Dunners. Im sure someone would help if you asked. Edited August 18, 2014 by KwS Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted August 18, 2014 Yea swing round some time and I'll show you what the go is. Heaps on 36s at pull n pay so can be a replacement for probably $10 Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted August 19, 2014 Yea swing round some time and I'll show you what the go is. Heaps on 36s at pull n pay so can be a replacement for probably $10 Pull and pay... Is that like pick a part?! Where bouts are they? Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted August 19, 2014 Yup same idea, down in the old burnside freezing works Quote Share this post Link to post Share on other sites
