cmscss 0 Report post Posted September 18, 2014 Hi There, I've replaced the batteries in one of my keys and am trying to programme it using the various guides I've found but am having no luck. This is the procedure I've tried: Insert key and turn to position 1 Remove key Simultaneously hold the unlock button for 15sec and press the lock button 3 times within 5sec After letting go of the unlock button the doors should lock and unlock to confirm it’s programmed Immediately follow the same procedure for all keys until all are programmed But instead of the doors locking/unlocking after step 4, the LED on the key starts flashing and the key doesn't work - I can confirm that both keys start the car. I can't find a manual for this car so the info I have may be incorrect - can anyone see what I'm doing wrong? Any pointers in the right direction would be much appreciated. Cheers Ben Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted September 18, 2014 (edited) (4) You must release, pause and press again... locks will lock & unlock to complete the procedure And you don't use procedure 1 & 2 again for the following keys or you will change the rolling code again All doors should be closed when doing this Edited September 18, 2014 by B.M.W Ltd Quote Share this post Link to post Share on other sites
cmscss 0 Report post Posted September 18, 2014 (edited) Thanks heaps for the reply but I'm still having trouble sorry - I tried this: Insert key and turn to position 1 Remove key Simultaneously hold the unlock button for 15sec and press the lock button 3 times within 5sec After letting go of the unlock button pause and press the unlock button once Do you have to hold the unlock key for 15sec or more then 15sec - maybe I'm holding it down for too long? When I release the unlock key (after pressing the lock key 3 times) the light blinks and if I then press the unlock key again, nothing happens. Do I have to pause longer until the blinks stop after releasing the unlock button maybe? Sorry if this is easy but I'm not sure what I'm doing wrong. Edited September 18, 2014 by cmscss Quote Share this post Link to post Share on other sites
cmscss 0 Report post Posted September 18, 2014 (edited) OK, so I found some info for an E39 which states that the driver's door must be closed or it will prevent all further programming. The first time I tried it, I'm pretty sure the driver's door was open - so I guess I've locked it out if the E46 works the same way? Is there a way to get the car to programme new keys using the original key (which still locks/unlocks the car)? Edited September 18, 2014 by cmscss Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted September 18, 2014 Where are you located ? Quote Share this post Link to post Share on other sites
M3_Power 636 Report post Posted September 18, 2014 (edited) For that procedure to work you must have the master key ... just because it unlocks the car doesn't mean that it is the master key. If you don't have the master key you have to reset it to the key that you have. Also you must have all doors and windows closed. If you are not sure the key you have is the master key ... put it in the ignition ... turn it on and off 5 times in rapid succession - this initialises it as the master key and then repeat the usual procedure (hold unlock, then lock 3 times) release ... then repeat for other keys. Edited September 18, 2014 by M3_Power Quote Share this post Link to post Share on other sites
cmscss 0 Report post Posted September 18, 2014 I'm located in Westmere - or Ponsonby during the day but happy to drive anywhere. Cheers Quote Share this post Link to post Share on other sites
cmscss 0 Report post Posted September 18, 2014 Sorry, crossed posts. @M3_Power I'm not sure what the master key is sorry - I was just given two IR remote keys, how can you tell which one is the master? Cheers Quote Share this post Link to post Share on other sites
cmscss 0 Report post Posted September 18, 2014 OK, have just looked up the master key and I definitely don't have one of those - do I have to order one? Quote Share this post Link to post Share on other sites
M3_Power 636 Report post Posted September 18, 2014 (edited) You can't without a scan tool. Here have a read of this ... this has the cut and paste procedure from BMW TIS I am gathering you have the older keys? (non diamond shape) http://www.ebay.com/gds/BMW-Key-Programming-Reprogramming-/10000000007275614/g.html Also are the keys originals or copies? Edited September 18, 2014 by M3_Power Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted September 18, 2014 Come and see me tomorrow Ben with all your keys Quote Share this post Link to post Share on other sites
cmscss 0 Report post Posted September 18, 2014 Sure thing Glenn, see you at around 9am. Cheers Quote Share this post Link to post Share on other sites
cmscss 0 Report post Posted September 18, 2014 Cheers Glen, thanks heaps. Quote Share this post Link to post Share on other sites
jeffbebe 1586 Report post Posted September 18, 2014 All sorted? If not, I live in Ponsonby and have done the procedure many times on different cars. Happy to help if needed. Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted September 18, 2014 It's all sorted 1 Quote Share this post Link to post Share on other sites
