thorburn 123 Report post Posted November 5, 2014 Engine position is determined by the camshaft sensor on the LS engines. - so the Internet tells me. Make up a 36-1 or 60-2 trigger wheel if it's going to be batch injection and wasted spark. Does link not have an option for LS trigger wheels Quote Share this post Link to post Share on other sites
samo455 7 Report post Posted November 6, 2014 yer i guy from link just cleared it up for me the options in there for some reason its called a ls1 3-12 or 5-10 and the numbers are to do with the width its running g4+ extreme so full sequential Quote Share this post Link to post Share on other sites
samo455 7 Report post Posted November 23, 2014 havent had much time or money this month but got the shifter hole sorted relocated 30mm back 10 mm right and 15mm up 2 Quote Share this post Link to post Share on other sites
samo455 7 Report post Posted January 11, 2015 got the wireing done had a radiator made added a aem 700hp pump and reg fuel pressure and oil pressure wired in to the uce for logging and saftey cutting turbo has not been done dont think my mate is very motivated thort add give it a qick start up just as a system check anyway https://www.facebook.com/video.php?v=794913870557077 Quote Share this post Link to post Share on other sites
samo455 7 Report post Posted January 23, 2015 ok now i no shes a runner time to move on my mates mate ray has not even started the mode for the turbo im told so iv decided to throw on a holset hx50 i wouldn't say its a happy fit but it fits i will need to make some heat shields here and there and have every thing ceramic coated butt it will work exhuast seams to exit nicely over the steer rack just below alti feeling confident Quote Share this post Link to post Share on other sites
polley 916 Report post Posted January 23, 2015 You're crazy. 1 Quote Share this post Link to post Share on other sites
will 169 Report post Posted January 23, 2015 You're crazy. pot-kettle-black Quote Share this post Link to post Share on other sites
