WYZEUP 283 Report post Posted September 28, 2014 So I'm looking to fit some wheels to my e39 but as it turns out is not an easy task with the centre bore etc.... So looking for some spacers that will also adapt the centre bore or if anyone knows of someone that could make some up Cheers Quote Share this post Link to post Share on other sites
grande 0 Report post Posted September 28, 2014 Do you have wheels? If this dosnt sell im going to part it out!http://www.trademe.co.nz/Browse/Listing.aspx?id=785268370 Quote Share this post Link to post Share on other sites
Allanw 1081 Report post Posted September 29, 2014 You can fit E60 wheel bearings(with the hubs included) to the front, and E60 drive flanges to the rear ( or get the E39 ones machined - though I suspect that should technically be certed). The threaded hole that is used to bolt on the discs will need to be drilled and tapped in the correct spot too. While all that is more expensive than spacers, it doesn't required a cert (all spacers and adapters do), and it means you can use a whole bunch more wheels without adapters or reboring the centres. Quote Share this post Link to post Share on other sites
twisted 45 Report post Posted September 29, 2014 Might have a set of Schnitzer type 3 one piece (concave type) up for sale soon. 18x9.5 square, currently running staggered rubber. E39 fitment. Quote Share this post Link to post Share on other sites
