Ingrid 11 Report post Posted February 1, 2015 Hi! I'm 22, almost finished with my piano performance degree, and I have a 1990 318i E30 that I absolutely love. I'm learning about how to fix and service it, partly because it's fun and partly because I'm a broke student. I'm replacing a leaking power steering hose (took it to a mechanic, but he just resealed it and it's still leaking, so I'll do it myself). It's the low-pressure hose coming off the ATF reservoir, and it should be a pretty simple job. However, since it's my only car and my boyfriend and I use it on a daily basis, I'm really screwed if I mess it up or break something. I was wondering if there's anyone out there in the Wellington area who would be willing to be sort of on call in case I catastrophically mess it up. I would totally give you some fresh-baked cookies. Thanks so much. 1 Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2144 Report post Posted February 1, 2015 I would totally give you some fresh-baked cookies. give me more info on said cookies?? Pretty simple job, quite common to be leaking or weeping at this age, recommend buying new, BMW dealer will have a listing, no idea on price, or get it made up at a hydraulics place, but probably need a spare part to show them what you want. the other alternative is delete the power steering system all together. a lot of 316i don't have it. The M40 engine in your car is not very heavy, steering is still pretty light when you are moving. make sure you get a smaller belt that bypasses the power steering pump, you don't want that spinning anymore. Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted February 1, 2015 Thumbs up for giving it a go yourself, should be a simple remove and replace but you never know with E30's. 1 Quote Share this post Link to post Share on other sites
_Matt_ 42 Report post Posted February 2, 2015 low pressure off the reservoir? if it's anything like an E28 you can just use a new hose from para rubber and a couple of hose clamps. Quote Share this post Link to post Share on other sites
