Andre3000 55 Report post Posted April 5, 2015 I'm in dire need of a lower ratio into my e30. Apparently the e28 eta diff internals are not compatible with non eta diffs? Anyone know of this issue or any way around it if it does exist? End result would be 2.93 in my med case e30 LSD. Lemme know. Cheers. Quote Share this post Link to post Share on other sites
FIAT 131R 223 Report post Posted April 5, 2015 Have you looked at using the backing plate off your E30 diff on the E28 diff and putting the LSD centre in your E28 diff. Not sure if you have to change the output shafts as well but there are a few on here with E28 history. Quote Share this post Link to post Share on other sites
Andre3000 55 Report post Posted April 6, 2015 Yeah I had a quick squiz re that option but i think the issue may be the carrier is too big to fit the crown onto. Plus that would mean i need to find an eta e28 diff which could prove difficult. Unless someone pipes up here with a good idea I'm gonna go with the 3.15 ratio for now and see how that goes, should make a marked difference considering im at 3.73 currently... Quote Share this post Link to post Share on other sites
