aw-krazy 45 Report post Posted April 14, 2015 As per title I'm looking for a front pair of callipers with the carriers, prefer without disc etc... Thanks! Quote Share this post Link to post Share on other sites
duvey 245 Report post Posted April 14, 2015 If they're going on the e36, have you researched how this will effect your brake bias, keeping the rear brakes stock 328? Quote Share this post Link to post Share on other sites
HELLBM 1697 Report post Posted April 14, 2015 Avaliable @ Hellbm Quote Share this post Link to post Share on other sites
aw-krazy 45 Report post Posted April 14, 2015 heap read up on the brake bias being upset by putting 330's on the front hence why i sourced a pair of e46 325i rear brakes which is supposed to work well paired up Quote Share this post Link to post Share on other sites
aw-krazy 45 Report post Posted April 18, 2015 and how much for the pair? Quote Share this post Link to post Share on other sites
aw-krazy 45 Report post Posted April 19, 2015 ahhh, that means i would have to swap spindles around :S Quote Share this post Link to post Share on other sites
aw-krazy 45 Report post Posted April 20, 2015 ahahah, i can always get somewhere to etch an ///M into the 330 callipers 1 Quote Share this post Link to post Share on other sites
aw-krazy 45 Report post Posted April 21, 2015 bump Quote Share this post Link to post Share on other sites
duvey 245 Report post Posted April 21, 2015 Cool man! Would be interested to hear results when its all up and running. Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted April 21, 2015 I have done a similar conversion to my E36 but I went with an E46 325i setup. This involved replacing the carriers on the front as the caliper is the same but the rotor is 300mm vs 282 stock. On the rear I run E46 325 I brakes that just bolt up. Brake bias seems fine. 1 Quote Share this post Link to post Share on other sites
