nath 174 Report post Posted December 5, 2005 Ok so i wanted keyless entry so i went and bought the most basic uniden alarm. red and yellow (constant hot and ignition switched) and ground are easy. these are the wires i need to find on my car: -parking light (i think it should be indicators) -negative door switch -lock -unlock where might these be found on my car? Quote Share this post Link to post Share on other sites
gmccormack 0 Report post Posted December 5, 2005 The lock/unlock (green/blue & yellow/blue) and door switch (brown/violet)can all be found behind the drivers side front speaker panel. The indicator wires (blue/red and blue/yellow from memory) can be found by removing the cardboard panel under the steering column. Quote Share this post Link to post Share on other sites
nath 174 Report post Posted December 5, 2005 man thanks SO much ill go find now! Quote Share this post Link to post Share on other sites
topless 14 Report post Posted December 5, 2005 (edited) If you use both left and right indicators for indicating arm/disarm, you will need to install diodes in the lines from the indicator wires. Otherwise just use one side, no diode needed. The indicator wires (blue/red and blue/yellow from memory) I think the right indicator wire is blue/black, left blue/red.. Edited December 5, 2005 by topless Quote Share this post Link to post Share on other sites
gmccormack 0 Report post Posted December 5, 2005 Yes, sorry if it's only a basic alarm you might need diodes or you can use a double pole relay but if your lucky the alarm might have to seperate output wires for the left and right indicators. William it is blue/black not blue/yellow, sorry. Quote Share this post Link to post Share on other sites
topless 14 Report post Posted December 5, 2005 Hey Graeme, not a bad memory, I just recently installed an alarm in the 318i (now manual, thanks... couple probs though..) so my mind was fresher than yours.. Quote Share this post Link to post Share on other sites
nz320i 0 Report post Posted December 5, 2005 YO, yeah they are right, i just bought an after market locking system for 30 bucks to go with mine as i heard you can burn out motors?? AND please tell me if you can get the lights going i have tried many times but either failed or only had one side of the car flashing cu Quote Share this post Link to post Share on other sites
nath 174 Report post Posted December 6, 2005 ok so the alarms god to go, i think you may have lock and unlosk around the wrong way, however i may have written it down the wrong way. i still need two diodes for the indicators which i will get when i have the time, then done!! cheers for the help graeme, i actually would have given up by now otherwise! ur info made it piss easy cheers Quote Share this post Link to post Share on other sites
