ant 0 Report post Posted June 9, 2015 Hi guys.. With my e39, if i leave it on the last position of the key(fuel pump primed / everything on) for 20-30 sec it wont start.. just cranks But if i start it before the 20-30 seconds it starts?? Obviously not a major problem but annoying sometimes Is this normal? Quote Share this post Link to post Share on other sites
jeff002 23 Report post Posted June 10, 2015 I havent had this issue with BMW.BUT the ALFA has same issue,I want to know the clue also. Quote Share this post Link to post Share on other sites
BMTHUG 1112 Report post Posted June 10, 2015 crank sensor, blocked fuel filter, cam sensor, many different reasons why it would do this, maf, throttle body the list goes on, process of elimination if you are doing it yourself, if a mechanic is doing it most likely they will be able to pin point the problem Quote Share this post Link to post Share on other sites
aja540i 1925 Report post Posted June 10, 2015 Mine has the opposite problem, if i try to start it before the steering wheel has finished moving down it just cranks and wont start, if i wait until the wheel is all the way down it starts first pop every time! Gotta love 16 year old electrics imagine how bad it would be if it was Italian! Quote Share this post Link to post Share on other sites
