allan
Door Chimes
Have a E46 compact upon opening drivers door chimes begin have had it turned down but still very irritating when having to listen to this when opening the door and working on the car with the drivers door open etc is their an easy way to turned off this option?. If so no doubt controlled by the general module, central body electrics have had a look but nothing obvious stood out in this section am I in the correct place and not seeing it or is it in another area. Thanks for any useful assistance.
Edited by tim 325
my E38 does that too, i can sympathise lol
edit: how are you going with that laptop?
Edited by _Ethrty-Andy_
Sweet, have used it twice first time was a full scan and errors all over the place cleared what I could. About a week later did another scan and no more new errors also had a look at turning on the rear window option needs further work. Have to watch out because having large fingers it's easy to hit the wrong key or two at once haha!.. Thanks again for getting it and having it set up.
