Jazzbass
Win some petrol
like how petrol companys are on the pulse of the market..
3 goes 11.74 11.19 11.12
Wonder what car its based on - 6 speed with 6 grand redline?
  Andrew said:
11.26 - and now i'm addicted. Where are you guys shifting?
First shift just below redline, then 5.5-5.7 for most other gears - you get a faster start if you wait to press the accelerator till just on green rather than holding down or pressing early.
Edit - pulling 11's on a car that has a 6 grand redline means it prolly turbs - so need to be able to rev between shifts to maintain boost dammit! Wheres the boost guage???
Edited by bravomikewhiskey
11.02 - 216.9kph
:pimp:
[edit] 11.01 212.8kph
:pimp: :pimp:
[edit][edit] 11.00 212.8kph
Come on.....
Edited by martyyn
Guest Andrew
  martyyn said:
11.02 - 216.9kph
:pimp:
:pimp: :pimp:
Come on.....
it gonnna kill you - i got 11 also - YOU JUST CAN'T GET 10 DAMMIT! ARG :angry:
This car goes from 0-100 in around 4 seconds.....
Dodge Viper or something??
  topless said:
Gareth's car??? :o
Ha! I dont M badge my car damn you!
Would be more like 0 - 100 in....eventually...
  Quote
haha.. you might just be a closet M-badger... :D
  Quote
not if Gus and I pushed it off a high cliff... :bounce:
Edited by topless
Hah...I wonder what the terminal velocity of my car is?
And yeah...you should have checked the glovebox...just after I pulled out of your place on sat i put my magnet ///M's on :P
Vt= \sqrt{{2mg \over C_d \rho A}}
where
Vt is the terminal velocity,
m is the mass of the falling object,
g is gravitational acceleration,
Cd is the drag coefficient,
ρ is the density of the fluid the object is falling through, and
A is the object's cross-sectional area.
where
So I would need to know how high that cliff is to get the right measurments of the density of the air from that alitude - and also I would have to assume that the car falls in one positon as not to screw up the drag coefficient.
Sounds like a project for a rainy day.
