Jimbob789 1 Report post Posted July 13, 2015 Hi all, Just purchased an m50 manifold to go onto my e36 328i, quick question, Before I go through with the swap, I was just looking for a part number and the only one I can find is near the throttle body (1 720 615 2.0). Would there be another one that I'm just not seeing? I've googled and googled but can't find what its from!! Anyone know if its from a 325i e36 or anything else? The part number is not recognised on realoem.com Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2144 Report post Posted July 13, 2015 google thinks its off a 2.0L engine, that was before i added the 2.0 part on the end, usually you ignore those suffexes. Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted July 14, 2015 I have a M50b25 one if needed and local. You can tell the difference by looking at the gaps between runners, the square holes should fit directly between each runner, if there is some gap between then it's the thinner 2.0 runners. Check ID photos here; http://www.e30zone.net/e30zonewiki/index.php/M5x_Inlet Quote Share this post Link to post Share on other sites
