wtbdeath
E90 330i Transmission oil changed
I decided to do a oil change on my 330i , with ZF 6 speed transmission.
The car is 2005 with 189k on it, on original transmission oil, of course....
Anyway, bought 10 litres of pentsion ATF 1 (full synthetic) rather than ZF Life guard , because: 1, it is cheaper. 2. it is full synthetic.
Also bought ZF filter kit.
I changed oil only first, the oil came out was nasty, car was having hard shifting from 1-> 2 and not so smoothing shifts after that.
Filled in 4.7L , car felt good, shifting after 2nd is super smooth, but still feel 1->2 some times bit hard.
Drove about 500km, dropped pan, did full filter change.
Now, is the interesting part, the 2 magnets on the filter are FILLED with black fine dusts / shavings , I don't think it can hold any more than that, I am glad I changed it.
put on new pan and bolts, I can see have a very very very minor leak from the sealing sleve, if you know what I am talking about, anyway, didn't buy that part and just left it as is.
Filled in 5.5L back to transmission ( reused 0.5L of old oil) , the oil came out prety good, I thought TC would hold some old oil and would be black, but not the case here.
I didn't reset adaption, no need to do it anyway, for the first 200km, I can tell the transmission is getting better and better, and after 500km, the hard shifts are totaly gone, shifts through all gears super smooth!
Total job is around $500 , I would do it again 40k later (changing the sealing sleve, otherwise I will just change oil, about $100 job). Well worth the money IMO.
Edit: From what I read on internet, ZF lifeguard is just semi-synthetic , I don't think it will work after 10 years, or 100k. It is thin oil to provide better fuel enconmy but the ATF1 I use didn't go any worse, I average 10.5L/100km for combined driving and drive it as it is meant to be driven...
Edited by wtbdeath
The E90 6 speed transmission must have the correct oil and the loom socket replacement is standard replacement when servicing the transmission with adaptation clearance, road test & recheck.... I saw "cheap" in your post. A word I seldom use looking after peoples cars.
Knowing what you are doing and do it cheaply is a common good practice I heard. :)
The reason "must" have the "correct" oil is because most of the oil on market are not compatible. The replacement oil is not even available in NZ.
Dealers quoted $63/L for lifeguard , semi synthetic , as trade account, I could get ~$40/L , but still much expensive than full synthetic Pension ATF1 replacement at $20/L.
For 1/3 of the price if using correct part, I could replace it 3 times as my wish and maybe still save some penny for beers.
Edited by wtbdeath
What ever......Do as you please
The point of this post was for whoever was thinking about a transmission oil change, they should change it, if it is over 5 years, or 100k, sooner the better. No many people doing it proactively until it is too late, it can be totally avoided and at a very reasonable price.
The point of this post was for whoever was thinking about a transmission oil change, they should change it, if it is over 5 years, or 100k, sooner the better. No many people doing it proactively until it is too late, it can be totally avoided and at a very reasonable price.[/quote
Exactly what I promote.. Using the correct oil and procedure, doing it once only
@wtbdeath how's it working out for you, and where'd you buy the Pentosin ATF-1?
