Apex Effects
87 pfl 318 F/S
1987 NZ New(Oct 87)
318i
4 door
Manual
Manual windows
Manual Sunroof(NO RUST)
Rebuilt brakes
Average paint(working on that)
good runner - slight miss due to afm being old
Wheels:
depending on price can come on
16x8.75+3/-2(fronts are -2 due to Motorsport Hardware 5mm spacers to clear brakes) Enkei Peak
Freshly refurbished with custom blue faces, polished outer lips(3.5") custom gunmetal midnight sparkle barrels 24k assembly bolts wrapped in 205/50r16 firestones and 1 cooper starfire
Interior:
Standard seats drives a bit shabby as were replacements for the recaros when they sold
standard coupe rear seat
Custom blue and black hounds tooth shift boot and handbrake boot by Fuzz Fabrics in the USA
Crack free dash
Dyed carpet
only thing in the interior that don't work is the tacho( Si board batteries likely the cause)
Door cards replaced from beige to black on grey hounds tooth
redyed rear parcel tray(Black)
Black sunvisors
have vinyl sun visor section to go with car(not installed)
Kenwood front speakers
Alpine rear 6.5"
Blaupunkt headunit
Exterior
Zinnoberrot
Chrome in good shape
Paint is average bit faded
rough around areas were the only rust was repaired
NO RUST
Sunroof Fully functional
Tail lights need new seals
Ellipsoid/Smiley upgrade Headlights
LEDs in indicators and tails
Engine& Driveline:
M10b18 - Great compression even over all cylinders
New Bosch plugs, Kami Leads, rotor and cap
New temp Sensor
gear box tight
Left diff axle seal weeps but has fresh oil an is full
Rear drive shaft universal replaced/re balanced
Front and rear brakes rebuild, powdercoated telecom green an mambo green(ran out of telcom green)
new Remsa Red pads front and rear
New Discs front, skimmed rears lots of life left
Motorsport hardware stud kit
Cusco Coilovers 8kg front 8k rear
wof till jan(now expired
Reg till December(now on hold)
3900 ono( with Enkei Peaks and coilovers)
1800 on standard suspension, factory seats and you bring your own wheels of choice or ill chuck a set of enkei rs's in 15x6.5 on it with wof able tires
027 349 6171(ask for jordan) - i have left the country now so to view best contact him(close friend and mechanic)
post-1713-0-04892800-1444105845_thumb.jp
post-1713-0-98651000-1444105917_thumb.jp
Edited by Apex Effects
You don't wanna sell seats and rails for factory seat and cash your way? Is exactly what I want to do
can do. what factory seats do you have? pm me details and how much cash your offering
If it's still around in another 3 months I might be interested :lol:
bump, price drop, as its sitting not getting the appropriate use a e30 deserves as i am now located in canada. it is stored with a good friend.
rego is now on hold till the new owner requires it to not be
