ceebee05 1 Report post Posted July 21, 2015 I'm keen to lower my standard E39 530i to the same ride height as the E39 M/sport. The M/sport is a nice ride. Can someone advise me whether it's simply different springs & what I'm up for if I use genuine parts? Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted July 21, 2015 proper motorsport cars are shocks, sway bars as well. Its called M sports suspension II, option S705A. 2 Quote Share this post Link to post Share on other sites
Allanw 1080 Report post Posted July 22, 2015 There's S704A too: M sports suspension - I don't know what the difference is, but our E39 is 704 rather than 705. It was really low, and I actually raised it about 20mm, with 10mm spacers in the strut mounts when I rebuild the suspension, so now it's normal low, instead of annoying low: The new Sachs shocks for the sport suspension are SUBSTANTIALLY more expensive than standard ones FYI Quote Share this post Link to post Share on other sites
ceebee05 1 Report post Posted July 27, 2015 (edited) Pretty sure you can just do springs , I did springs and shocks on my 528 well worth doing . Msport shocks are firmer so you get a sharper drive doing both. Best upgrade is rear sway bar most have a prissy rear bar that lets the rear end roll and induces understeer quite early. Swap it out for an Msport bar , you will need new bushes as well - go urethane proper motorsport cars are shocks, sway bars as well. Its called M sports suspension II, option S705A. There's S704A too: M sports suspension - I don't know what the difference is, but our E39 is 704 rather than 705. It was really low, and I actually raised it about 20mm, with 10mm spacers in the strut mounts when I rebuild the suspension, so now it's normal low, instead of annoying low: The new Sachs shocks for the sport suspension are SUBSTANTIALLY more expensive than standard ones FYI Edited August 13, 2015 by ceebee05 Quote Share this post Link to post Share on other sites
ceebee05 1 Report post Posted July 27, 2015 Thanks to you all for your help. Quote Share this post Link to post Share on other sites
ceebee05 1 Report post Posted October 17, 2015 Want to thank 3pedals, hybrid & Allanw for their help. The E39 rides great. 1 Quote Share this post Link to post Share on other sites
Allanw 1080 Report post Posted October 17, 2015 NICE! Quote Share this post Link to post Share on other sites
