cliffdunedin 8 Report post Posted August 26, 2015 I noticed a few days ago that there was a stutter/vibration that had developed as I accelerated from stop or under low RPM to a higher RPM, it seemed to leave at higher speeds and as the engine heated up. I went home and i saw the fan slightly wobbly so rolled up a newspaper and bingo the fan clutch was gone, I ended up buying a new clutch and installing it, the wobble of the fan is gone but that stutter/vibration is still there. I don't seem to lose any power with these vibrations but am stumped what it could be because of this no power loss. Does anyone have any suggestions? nb: Waterpump and belt has been replaced in the last year. TIA guys Quote Share this post Link to post Share on other sites
B.M.W Ltd 950 Report post Posted August 26, 2015 Scan it... I need to say no more Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted August 26, 2015 Scan it... I need to say no more Sorry forgot to mention, no codes. Quote Share this post Link to post Share on other sites
B.M.W Ltd 950 Report post Posted August 26, 2015 Sorry forgot to mention, no codes. Then the brain needs to kick in with hands, ears and a nose under the bonnet unfortunately with a few other test tools and maybe a real or better scan tool. I'm thinking unmetered air flow as preliminary causing lean mixtures Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted September 28, 2015 Bit of a late update but it was a cracked CCV pipe! Noticed the small amount of oil leaking by chance when checking that the camshaft sensor was fine. Quote Share this post Link to post Share on other sites
polley 916 Report post Posted September 29, 2015 Bit of a late update but it was a cracked CCV pipe! Noticed the small amount of oil leaking by chance when checking that the camshaft sensor was fine. As Glenn mentioned, unmetered air flow. Quote Share this post Link to post Share on other sites
