Mark 178 Report post Posted September 8, 2015 Trying to figure out what is causing a strange intermittent vibration/rumble from the rear of my E46 touring when driving. When driving under constant throttle (at a steady speed) I will get a rumbling/vibration from the rear of the car which sounds similar to driving on a rumble strip. This isn't constant, it will happen in 2 seconds bursts intermittently and seemingly at random. When this happens the revs drop slightly and then recover again when the rumbling stops. Trying to think what it could be: Binding caliper? Crap tyres (it currently has shitty chinese tyres on it which I will change when funds allow)? Something to do with the diff? Any suggestions? Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted September 8, 2015 rear wheel bearing giving up ?? also have had quite a few rear uni joints on the driveshaft seize up one way . Quote Share this post Link to post Share on other sites
Rubix 434 Report post Posted September 8, 2015 Have always heard that description when a wheel bearing is failing, sounds like going over rumble strip/Judder bars etc. Quote Share this post Link to post Share on other sites
