musccoo
E30 M20 Cam seal replacement
So I'm doing my timing belt, water pump etc and want to do the cam seal while I'm there.
Ive got the pulley off only problem is I can't get the cam seal housing off. What's the best way to get it off without hacking the head with a screwdriver behind it..? It seems really stuck
Thanks
Edited by potatomash
But how do I get it in behind without scratching the head?
Sent from my HTC One M9 using Tapatalk
Be careful or better - use a gasket scraper to get behind it. I should come away relatively easily.
Thanks guys I managed by tapping it with a punch to one side to loosen it and get it spinning then was able to use some flat heads. I changed seal then put it back on with some gasket sealer *just in case*
