Ahmedsinc 414 Report post Posted September 21, 2015 As above, does anyone have tips on how to get the bloody thing back in? Was quite difficult to slide the bottom knuckle all the way to the end of the splined shaft to get it off, more so now. Have installed S50 headers so space is even tighter than when they came out. Thanks Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted September 21, 2015 Unbolt the steering rack and move it forward slightly 2 Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted September 21, 2015 Unbolt the steering rack and move it forward slightly Argh, why the hell didn't I think of that! Thanks Glenn! Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted September 21, 2015 Yes, steering rack has to be moved forward. I did this dozens of times on my E36 V8. Not the most fun job, especially when it goes between a custom 4-2-1 manifold haha. On a side note, take care as to not damage the splines, it can be easily done. Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted September 22, 2015 Yes, steering rack has to be moved forward. I did this dozens of times on my E36 V8. Not the most fun job, especially when it goes between a custom 4-2-1 manifold haha. On a side note, take care as to not damage the splines, it can be easily done. Yup, the aluminium knuckles seem pretty soft & the spline count is far greater than I had anticipated. Just hoping I can line the sight marks back up when it goes in, probably the least enjoyable job so far! When you did the job on your coupe, did you need to tap the knuckles home with a hammer or were you able to slide them on just using your hands? Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted September 22, 2015 Gave the bugger three good doses of AC-90 and once the knuckles aligned with the splines properly it slid straight on, didn't have to unbolt the rack at all in the end. I suspect I got lucky - thanks for the advice gents! Quote Share this post Link to post Share on other sites
