EuroAllDay 0 Report post Posted October 30, 2015 I know this won't be of too much help posting here as you can't physically see the wheel but I got told by a mate who was following me that my "right rear wheel was wobbling 1 inch if that", I have jacked up the car and checked for play, don't really have any play or anything, only thing I have noticed that isn't right is when I go over small bumps or speed bumps there's a slight knock sound, I have no idea what it would be as I'm not the most mechanically minded, control arm bushing? bad tire, bad rim? I have to say there is camber wear on the inside of my tires, would a wheel alignment and balance + new rear tires fix this? Cheers. any help is appreciated Quote Share this post Link to post Share on other sites
euroriffic 626 Report post Posted October 31, 2015 Sounds like you need to take it to a professional. Sounds pretty serious/dangerous Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted October 31, 2015 Sounds like you need to take it to a professional. Sounds pretty serious/dangerous +1 The OP can ring me tomorrow Ph: (09) 2722546 Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted October 31, 2015 i t wont be 25mm thats huge.even a very small runout can look much worse that it is.Def worth getting it looked at though! Quote Share this post Link to post Share on other sites
EuroAllDay 0 Report post Posted November 1, 2015 Will give you a call Glenn, just working around my work schedule. I was at 40 psi on my tires put them down to about 33, seems a lot better, not sure if this was the issue, hard to see as I'm always driving. Quote Share this post Link to post Share on other sites
NVADER 54 Report post Posted November 1, 2015 Are the rims hub centric? If so, a missing hub ring can make things look pretty disturbing Quote Share this post Link to post Share on other sites
EuroAllDay 0 Report post Posted November 2, 2015 Are the rims hub centric? If so, a missing hub ring can make things look pretty disturbing Not too sure mate, It's a 328i e46 1998 stock rims. Cheers. Quote Share this post Link to post Share on other sites
