Aaron320iSmith 0 Report post Posted January 2, 2006 Can nos be run with carbs? im not sure how exactly it works, something like, push the button whick opens valve, and nos is injected into intake manifold then into cylinder causing a hire rate of fuel burning or is it the nos that ignites and creates a higher compression? Quote Share this post Link to post Share on other sites
Napier_E36 0 Report post Posted January 2, 2006 It hardly seems worth doing that to a 320i - put the money into an engine conversion!! Lots more fun! Quote Share this post Link to post Share on other sites
topless 7 Report post Posted January 2, 2006 you need to inject nos and fuel into the carb throat at the same time... in metered amounts obviously... Quote Share this post Link to post Share on other sites
cainchapman 0 Report post Posted January 2, 2006 Yes, otherwise the Americans would never have been able to do it until the 90's. Go and see Grunter (Grant Sylvester) at Sydenham Park in Moorhouse, he would be the best place to start in CHC. Quote Share this post Link to post Share on other sites
Aaron320iSmith 0 Report post Posted January 2, 2006 going in a triple carb 2.5 m20 Quote Share this post Link to post Share on other sites
