Herbmiester 913 Report post Posted November 21, 2015 (edited) So I got my E46 330ci back from the mechanic after getting a number of oil leaks fixed but it was throwing fault codes so I plugged in my OBD2 reader and found out it was all related to the ICV I pulled off the ICV and found out that it wasn't actually connected correctly :banghead: , I cleaned it anyway and while I was there I checked the DISA and lo and behold the flap was just spinning. The vacuum seems ok so may just have fix the flap. Since the flap pin was just about falling out I removed it and the flap. I reassembled it without the flap but got faults relating to lean condition. I need either a replacement DISA or a kit. Any suggestions? Edited November 21, 2015 by Herbmiester Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2125 Report post Posted November 21, 2015 Can just leave it unplugged Quote Share this post Link to post Share on other sites
Herbmiester 913 Report post Posted November 21, 2015 I have been driving it with no flap and so far no problems but I suspect there is an air leak as the seals and the fit of the shaft in the hole is loose. Quote Share this post Link to post Share on other sites
