qube 3568 Report post Posted December 1, 2015 Have this light coming up on the E90 but as far as I can tell all the lights are working fine? The PO has changed the yellow bulbs to white ones - could that be causing the error? Quote Share this post Link to post Share on other sites
*Glenn* 854 Report post Posted December 1, 2015 Yes Quote Share this post Link to post Share on other sites
qube 3568 Report post Posted January 20, 2016 finally got around to replacing these with new bulbs that were advertised as "error free" but made no difference. do i need to get the fault codes cleared to make this warning light go away? glenn should i bring it to you :) Quote Share this post Link to post Share on other sites
*Glenn* 854 Report post Posted January 20, 2016 No... put the right bulbs in or get someone to code out the cold test... we don't get involved with AM substitutes Quote Share this post Link to post Share on other sites
qube 3568 Report post Posted January 20, 2016 so its not a matter of getting the faults cleared and its actually an issue with the bulbs themselves? Quote Share this post Link to post Share on other sites
*Glenn* 854 Report post Posted January 20, 2016 Yes Quote Share this post Link to post Share on other sites
