Anthony M3
10W-60 TWS castrol
^Have you done bearings Tom? At what Kms would you recommend it?
No haven't done mine as I've only done 30k km.
As for recommendation, I would say probably nearing the 80-100kkm mark to be safe, but it can depend on how the car was treated.
  • Like 1
Rod bearing issue on the s54 motor was never caused by oil, it was always a manufacturing tolerance issue and oil pump issue.
Oil is oil ... If it is the right working range then it'll be fine.
Big end bearings are a maintenance item anyway.
Like Josh said, I'd be more worried about cams and cam followers snd I might add headgasket. Those seem to fail at a much much higher rate than big end bearings, especially if driven hard.
I was personally referring to S65 and S85 engines of whom I know two of personally who have now gone and had SN oil before hand. But speaking to the Taylor Automotive guys, it's a pick up with the oil from sump.. Can't remember now.
For the sake of $5 for me, I'm going to stick with TWS. Plus it gets delivered to work. Bonus service.
