BLACK DORIS 9 Report post Posted December 20, 2015 Hey all, been a while. Noob question here but wondered if any e30 owners know if most retractable seatbelt mechanisms from the early 90's will work/fit into an e30? Very slight bit of fraying on the drivers side seatbelt of the wagon. Needs replacing for the wof so only today and tomorrow to source and replace before xmas. There's one on TM but wondered if I could just use a seatbelt mechanism from any model vehicle of a similar era (1989/90). If so I'll just check out a local wreckers. (We're now living in RotoVegas...) Thanks in adv and merry xmas. Rio Quote Share this post Link to post Share on other sites
Mark 178 Report post Posted December 20, 2015 (edited) See my project log here... from when I replaced my old belts. http://bimmersport.co.nz/topic/48689-ac-schnitzer-e30-project-log/?p=586413 If your current belts are anchored through the floor then generic belts should work. If they're anchored to the seat then it's a bit of a different story. You'll need to remove the seat to get the old seatbelt stalk out too. Edited December 20, 2015 by _Mark_ 1 Quote Share this post Link to post Share on other sites
BLACK DORIS 9 Report post Posted December 20, 2015 See my project log here... from when I replaced my old belts. http://bimmersport.co.nz/topic/48689-ac-schnitzer-e30-project-log/?p=586413 If your current belts are anchored through the floor then generic belts should work. If they're anchored to the seat then it's a bit of a different story. You'll need to remove the seat to get the old seatbelt stalk out too. Thanks Mark, will check out the link. Had a quick look at the set up in mine and appears to be anchored at the base of the seat. Murphy's. Quote Share this post Link to post Share on other sites
jonoe30 53 Report post Posted December 20, 2015 Another option... There are a couple of places up here in Auckland which replace the webbing on your existing unit. I have used one up here in Penrose a few years ago on a Honda seatbelt, I think it cost around $100, I took the whole seatbelt assembly out and gave it to them... had it back the next day. There might be someone Rotorua who offers the same service. 1 Quote Share this post Link to post Share on other sites
