Blackfrogg
Power steering shop
Wondering if anyone can recommend a good power steering shop that is around central auckland? Need some custom lines run. Google only tells me to go to the shore or out east, which I dont really want to do unless I absolutely have to (no WoF/reg).
Also looking for some recommendations for an engineer to do some FEA or practical testing on my hubs and rear shock towers after changing to true coilovers in my e30. Wouldnt even know where to start looking for someone like that so anything is helpful.
Thanks
Edited by Blackfrogg
Any hydraulics shop can hook you up with custom lines, should be easy to find one central. I can't recommend one but it's a pretty simple ask, difficult to screw up.
Hydrolink or pirtec shops can make up hydraulic lines as mentioned.
FEA is expensive unless you have contacts. Depends on what questions you want to answer. Basic calcs and logic may offer what you need before spending money.
