qube 3571 Report post Posted December 27, 2015 after installing the dynavin clone into my car, when i turn the key to position 1 to get power for the stereo, it makes a couple of loud popping noises while starting up the speakers themselves are working fine and the problem only started after removing the factory unit and replacing it with the android based headunit. any ideas? Quote Share this post Link to post Share on other sites
Haitoman 110 Report post Posted December 27, 2015 It's actually quite normal for the output of an amp to make speakers pop at switch on. That is why you usually turn on the amp or whatever and then about two seconds later you hear a click and then sound. The solution is to build a short delay circuit eg. http://www.eleccircuit.com/simple-delay-speakers/ so that a double pole relay connects the speakers a few seconds after the amp or whatever is switched on. It's normal, just you usually can't hear it. Quote Share this post Link to post Share on other sites
qube 3571 Report post Posted December 27, 2015 its quite loud though and it wasnt there before. only after i switched to the other headunit...? Quote Share this post Link to post Share on other sites
Haitoman 110 Report post Posted December 28, 2015 its quite loud though and it wasnt there before. only after i switched to the other headunit...? Yeh, it is the pre-amp in the new head unit. It is quite normal as I said. Build a simple speaker delay. Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted December 28, 2015 As Andrew said above. Its also called a 'speaker dethump' circuit Quote Share this post Link to post Share on other sites
