HaNs 226 Report post Posted February 8, 2016 Installed my kill switch in the track car today Now in first gear at 2,000 rpm at WOT there is a big cut (can't drive through it) in first gear only Car is a 1995 obd1 manual. Kill switch kills ECU power, main battery, ignition and alt. Any suggestions? Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted February 8, 2016 Any ideas? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted February 8, 2016 Losing a connection in the wiring under torque or something to do with the way you have done this "Kill switch kills ECU power, main battery, ignition and alt" which could also be due to torque and engine movement Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted February 8, 2016 Losing a connection in the wiring under torque or something to do with the way you have done this "Kill switch kills ECU power, main battery, ignition and alt" which could also be due to torque and engine movement Seems odd that it only does it in first and always at 2000 rpm only. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted February 9, 2016 I realise that. Can you not pick up whether your loosing fuel, ignition or DME power supply on the dyno at work ? Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted February 9, 2016 I realise that. Can you not pick up whether your loosing fuel, ignition or DME power supply on the dyno at work ? Moved to Chicane Racewear so no dyno access during the week. Might bypass the switch tonight and take it for a drive. Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted February 9, 2016 By passed switch, still does it. Didn't seem to do when cold. Will drive it cold tomorrow. Will also check coil pack resistance and maybe pump voltage. Still has me confused as to why it only does it in first Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted February 10, 2016 Intake clamp letting air in! Plug gap was way off also, but not an issue. 1 Quote Share this post Link to post Share on other sites
