WYZEUP
WTB: E36 pedal box
As above looking for a e36 manual pedal box as need the brake and clutch setup.
let me know what you have..
Just so as you know, the auto and manual brackets are the same. You just hang a clutch pedal and master off the other side of it (with manual brake pedal too). The pedals them selves aren't too pricey from dealers etc. If you're going to do it check with Will as to which gas pedal he used and if the e30 arrangement is compatible with the e36 gear.
  • Like 1
