Dogballs 124 Report post Posted February 19, 2016 Hi, - If someone has a 5speed manual box sitting in front of them... I need a couple of measurements as per picture. I need the distance from the tip of the input shaft to the straight edge (surface of bell housing) and the length of the pilot bearing section. this is for a e46 manual conversion. The pic is of the 6speed box with the shorter input shaft, but what I have is a flywheel and clutch kit for a S54. I plan to use the 6speed clutch plate with the S54 kit and make an adaptor to use the standard pilot bearing in the crank instead of the unique 6speed flywheel.. thanks for your help. Quote Share this post Link to post Share on other sites
FIAT 131R 223 Report post Posted February 20, 2016 Do you come to Wellington as I have 6 speed S54 gear boxes and a 5 speed ZF with flywheels etc etc. I am around tomorrow 021 449 242. You can do the measurements yourself to get exactly what you need and see the options. 1 Quote Share this post Link to post Share on other sites
Dogballs 124 Report post Posted February 20, 2016 thanks Geoff, - just what I needed! Quote Share this post Link to post Share on other sites
