325GRANT
wheres your radiator overflow?
mines on the drivers side, but i noticed that some E30s have them on the passenger side. (photo below)
what year / model / euro import / jap import do these come in?
any help would be awesome
Edited by 325GRANT
I'm pretty sure my mates wrx has it out the passengers side. Why's that? You looking for some parts or somethin?
I think i missunderstood your ?? though.
Edited by rolls_on_19
the e30 FL had them on the passenger side, the pre FL (yours) on the drivers
to change to e30 FL you will need FL waterpump, hoses that connect the overflow tank and the overflow tank itself. bear in mind that the return to the radiator will swap sides too.
Guest Andrew
so does pre and post FL use the same radiator?
no - or waterpump - or timing system (etc etc) It can become a bit of a PITA to switch to the facelift cooling system.
What I would do - is just get a custom hose made up and move it to the other side (it should still flow properly)
