Quinn 1 Report post Posted March 9, 2016 (edited) Hi guys, I have a E28 with a 1JZGTE in it and I want to wire up the factory BMW Tacho to the Toyota computer. I have had the cluster at Robinson Instruments and it's all good. I have located the pulse output pin on the Toyota computer however when connected the Tacho pops up for about 2sec then dies. The Toyota outputs a 12v signal and I was wondering if the BMW used something different? Any advice on what the voltage, impedance etc of the tacho is would be great so I can try to solve the Japanese - German no speaky problems. Thanks!! PS the reason it is urgent is because the dash is in pieces and I have to move it by the weekend so I'd love to solve this ASAP ;-) Edited March 9, 2016 by Quinn Quote Share this post Link to post Share on other sites
aja540i 1925 Report post Posted March 10, 2016 Im no expert but i believe the BMW tacho will just receive a 12v pulse from the coil supply and interperet that internally to display rpm,,the toyota tacho probably gets a signal from the ecu which could be a changing voltage or even a PWM signal, it might be as simple as running a 12v supply wire from the low tension side of one coil pack into the tacho, but more homework would be needed on that. Quote Share this post Link to post Share on other sites
Quinn 1 Report post Posted March 10, 2016 I have spoken again to the guys at Robinsons and they said they tested the tacho with a 12v square wave pulse and it worked fine. I have checked the manual for the Toyota and it says the computer puts out a 12v signal so we are now playing around with which pin to use (apparently it's the blue plug pin no.8) I'll keep you posted so that if I solve it and anyone else is looking to re-power a bmw with a Toyota motor they'll learn from my expensive exploration. Quote Share this post Link to post Share on other sites
