lidu278 3 Report post Posted April 18, 2016 Hey guys, My Windows on my 1986 325i e30 have stopped working, have changed fuses still no go. Anyone got any suggestions on fixing this? Thanks Quote Share this post Link to post Share on other sites
lidu278 3 Report post Posted April 18, 2016 Also sunroof won't work. Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Mark 178 Report post Posted April 18, 2016 Have you accidentally pushed the circuit breaker on the dash that disables all windows / sunroof? Looks like the second button from left in this photo. 1 Quote Share this post Link to post Share on other sites
lidu278 3 Report post Posted April 19, 2016 I have tried that and doesn't work. Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted April 19, 2016 No one is going to be able to tell you. Get yourself a multimeter and do some troubleshooting. Do the switches have lights on? Indication there is power to the switches? Power at the fuse? Power at the motors? 2 Quote Share this post Link to post Share on other sites
Waltsbm 1 Report post Posted July 12, 2018 Have a look for the big plug inside the drivers door frame. When you open the door you see a fairly large flexible rubber tube. Peel back the rubber on the door frame, not the door. There should be a big multi pin plug there. Spray the plug with CRC or similar, leave for sometime then gently pull the plug apart. Clean all pins with CRC and reassemble. This may work it did for me, water must get into the plug. Not sure if it affected the sunroof on mine, but suspect it did as the windows and sunroof are linked together. Quote Share this post Link to post Share on other sites
