needsprings 3 Report post Posted June 14, 2016 How well/easy does the manual transmission from a m50b25 bolt up to a m52bxx?Is it it the realm of just a straight swap or is there some fine tweaking involved somewhere? I know it's probably already been asked, but google just inundates me with m50 manifold swap threads. Cheers. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted June 14, 2016 yes bolts up no problem at all. make sure you research compatibility between gearbox flywheel/clutch setup and the starter motor 1 Quote Share this post Link to post Share on other sites
Hellrot 325Ti 0 Report post Posted June 14, 2016 yes bolts up no problem at all. make sure you research compatibility between gearbox flywheel/clutch setup and the starter motor Reece just missed out on buying my conversion when you impulse bought it! Have to be quick to snap up a cheap deal Quote Share this post Link to post Share on other sites
