needsprings
*generic manual conversion swap question*
How well/easy does the manual transmission from a m50b25 bolt up to a m52bxx?
Is it it the realm of just a straight swap or is there some fine tweaking involved somewhere?
I know it's probably already been asked, but google just inundates me with m50 manifold swap threads. Cheers.
yes bolts up no problem at all.
make sure you research compatibility between gearbox flywheel/clutch setup and the starter motor
Reece just missed out on buying my conversion when you impulse bought it! Have to be quick to snap up a cheap deal :)
