qube 3571 Report post Posted July 11, 2016 Any recommendations on who has a hydraulic press to remove and fit new bushings for the control arms in my e39? About to order a pair of bushings for now, but thinking whether I should go all out and replace all/most of the suspension components at the same time.. What are the main ones to replace if not all of them? Quote Share this post Link to post Share on other sites
Allanw 1078 Report post Posted July 11, 2016 Any recommendations on who has a hydraulic press to remove and fit new bushings for the control arms in my e39? About to order a pair of bushings for now, but thinking whether I should go all out and replace all/most of the suspension components at the same time.. What are the main ones to replace if not all of them? Do the lot - I did on ours, and it makes it so tight and direct (though I went powerflex for a number of them too!). Quote Share this post Link to post Share on other sites
qube 3571 Report post Posted July 11, 2016 im considering replacing the whole front upper and lower arms with bushings with lemforder ones.. or is that not necessary? Quote Share this post Link to post Share on other sites
my_e36 43 Report post Posted July 13, 2016 Highly recommend Autolign in Mt Wellington for install. Also recommend Nolathan bushes, makes a huge difference in handling compare to the old worn rubber one. Sent from my Nexus 6 using Tapatalk 1 Quote Share this post Link to post Share on other sites
