Lucan 196 Report post Posted July 31, 2016 Looking up using a resurfaced 228mm S14 flywheel, anyone got one floating around? How much should I expect to pay for one? I assume they're hard to come by Cheers, Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3034 Report post Posted August 1, 2016 A pretty rare item for sure, as for pricing, hmm very hard to tell. Best bet would probably be to look overseas, try s14.net and s14power forums maybe? The teeth spacing on the s14 flywheel is quite specific as well, as I found out, so you might need a starter motor as well (or possibly just the gear teeth off the end). Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted August 1, 2016 Yea I figured they might be hard to come by - I have found one farily cheap in Aus but trying to get him to ship it seems to be a problem. I've read a couple times that the M30 starter will work, am stuck with a Getrag 240 and AFAIK the S14 flywheel is the biggest it'll fit. Quote Share this post Link to post Share on other sites
