Haz77 0 Report post Posted August 25, 2016 (edited) Got a front fog light out on my 2000 530 Motorsport, Had a girly look & cant see how it comes out, had a Google & some suggestion that the bumper needs to come off??!!! Anyway, to avoid breaking something or wasting all day trying, can anyone tell me just how to remove them? its the passenger side with the air intake. Cheers. Edited August 25, 2016 by Haz77 Quote Share this post Link to post Share on other sites
hqstu 780 Report post Posted August 25, 2016 No need to remove bumper. the black plastic surround will pop off when pulled in correct direction. Grab the black surround that wraps around the foglight on the inboard side of the light and pull on this both frontwards and sideways towards outboard of car. The flat bit of the surround with the alternator air intake should pop its two tabs out on the inboard edge and the plastic will come right off. Don't wrench at it, just give it a moderate controlled pull and you'll work it out from seeing what happens. Then a single bolt to remove light. Installation is a reversal of above procedure... Easy peasy... Good chance to give the area a good clean and even paint the black surround. 1 Quote Share this post Link to post Share on other sites
Young Thrash Driver 1021 Report post Posted August 25, 2016 You will worry it will break- just be careful. If you are missing your shields under the car you may be able to reach in and push it out. Quote Share this post Link to post Share on other sites
