kwhelan 242 Report post Posted September 2, 2016 Got a spare brand new Fuel pump, not the whole assembly just the pump motor and fitting kit as per ebay. Has some installation to fit but works perfectly inside the original assembly if motor has failed. 20 mins to fit and a probably better than risking a 2nd hand unit probably fit e46 as well but havn't compared flow ratings $45 Quote Share this post Link to post Share on other sites
jom 98 Report post Posted September 2, 2016 Shame no-one does a tank sender unit kit. It's usually the bit that fails on the combined pump/sender assembly... I've replaced two Quote Share this post Link to post Share on other sites
eeee36 0 Report post Posted September 15, 2016 On Friday, September 02, 2016 at 5:09 PM, jom said: Shame no-one does a tank sender unit kit. It's usually the bit that fails on the combined pump/sender assembly... I've replaced two I have a couple of sender units as I got one with a new pump. If it's any use pm me Quote Share this post Link to post Share on other sites
