BM WORLD 1291 Report post Posted November 10, 2016 have this large case 210mm crown type diff from a e46 330D 2.81 ratio larger axles like in e46 330i manuals larger brakes , bearings , stronger diff carrier to suit the diff etc suitable for big power 330i . turbo , supercharger , V8 etc can sell separately etc $1500 for the whole lot 021433600 [email protected] see the difference between the medium case e46 330i diff . std e46 330i drivehshaft will bolt up to this larger 330D diff Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted November 18, 2016 Will the larger case diff bolt up to a standard rear subframe or are the mounting holes different? Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted November 18, 2016 1 hour ago, zero said: Will the larger case diff bolt up to a standard rear subframe or are the mounting holes different? you will need the matching subframe to suit this diff , mounting points different . also its built stronger etc will come with the diff Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted November 18, 2016 How much just for the sub frame as I will probably go lsd? Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted November 18, 2016 12 hours ago, zero said: How much just for the sub frame as I will probably go lsd? so you want the diff head and subframe ? as they are a matching kit you could fit a lsd pack into the large case diff call me to discuss 021433600 Quote Share this post Link to post Share on other sites
